Forums >> Workflow & Implementation >> Hardware >> Revit 2011 stays running after close
Tue, Feb 15, 2011 at 4:13:52 PM | Revit 2011 stays running after close
xcrogers
I've noticed that my Revit 2011 stays running after successfully closing (without errors). No window is open, but the task manager shows Revit is open and continues to hoard more and more memory. Any thoughts/suggestions? Thank you.
Tue, Feb 15, 2011 at 5:39:16 PM | Revit 2011 stays running after close
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Probably just need to restart your machine.  Sometimes applications flip out for the duration of a windows session...  or is this a common occurrence, every time you try to close revit?
Wed, Feb 16, 2011 at 8:01:38 AM | Revit 2011 stays running after close
If you have worked a long time in a Revit session, we have seen that it sometimes takes Revit as much as 5 - 10 minutes to fully shutdown but you can do other things while it is working.  If you are wanting to shut down the computer, you can just slam Revit shut by ending the program through ctrl-alt-delete.
Wed, Apr 6, 2011 at 5:30:56 PM | Revit 2011 stays running after close
xcrogers
This seems to be a common occurance (whenever i notice my machine running slow after revit being open) I'll go and check. This sometimes is 5-10 min or other times nearly an hour. We've had theses machines spec'ed for Revit, more Ram, faster/larger video card ok'ed by autodesk, faster processer etc etc. Our model is large (260 meg with a 4 linked models of nearly equal size) but that doesnt seem to explain why the program itself would continue to churn away long after closing...
Wed, Apr 6, 2011 at 7:55:34 PM | Revit 2011 stays running after close
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
if you got all your proyects saved... ( and you wait to revit to create the newer version of the file) it should not be problematic shut it down... it happens to me with long use too.
Revit 2011 Properties box
Wed, Dec 8, 2010 at 8:45:57 AM
i7 860 for Revit - feedback?
Wed, Jan 5, 2011 at 2:09:03 PM
my renders stays with black svreen
Fri, Jul 18, 2008 at 5:33:13 AM
Project won't close
Mon, Mar 7, 2016 at 12:49:47 PM
Revit 2010 crashes a lot on a 2 GB RAM computer?
Sat, Apr 17, 2010 at 1:53:45 PM
Page generation time: 2.7894
