14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Glass Opacity
in Revit 2009, how do I modify the glass opacity? The glass is too clear, and I want to render it more sloid, like blinds are behind the glass, so I can see more of the glass color, like blue / green, or blue, but the glass is too clear, and I am not seeing the color in my renderings thanks
Opacity is in the material settings. You might think about having mutiple glass types in your project and assign accordingly
I hav eread a bunch of threads regarding this issue, but whenI go to the material dialoge box for my glass, and go to the rendered apperance tab, the only opptions I have avalable to me ar ethe following: Settings/Materials/Glass (Material Class)/Glass (Actual Material Name) Rendered Apperance: Solid Glass Properties: 1. Color (transmittance) 2. Reflectance 3. Index of Refraction 4. Roughness 5. Bump Pattern Thats all I have access to, I still do not knwo where to find Opacity? Pls I need help..hahahaha
For shaded views see the first image - for rendered glass, look at the second image. NOTE: These settings are not available on all default glass materials>
wwhUB... THANKS.. that is exasctly what I needed.... wow.. i have been struggling for yrs to find this out.. thanks
19 Posts No Rating |
It seems I have answered my own question as it seems there is an important toggle under material editor.
Graphics allows transparency
Appearance allows reflectance
opacity control in shaded regions |
Mon, Oct 30, 2006 at 4:31:11 PM
Rendering transparent gradients |
Tue, Jul 13, 2010 at 1:58:50 PM
Opacity Maping- Planer not boxed |
Wed, Jun 13, 2012 at 1:44:29 PM
how to reduce opacity of imported image file in sheets |
Sat, Dec 1, 2007 at 10:53:50 PM
Transparency of glass windows in 3d views |
Wed, Aug 5, 2009 at 10:43:37 AM
