24 Users Online (23 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> plotting issues multiple sheet sizes
Tue, Feb 15, 2011 at 7:30:45 AM | plotting issues multiple sheet sizes
kgomez
has anyone had an issue with plotting from the same printer but using different sheet sizes?
for example:  revit can store all the information about print set-ups. we have an oce tds600 printer with 4 rolls.  but when i set up a 24x36 print the windows system printer for the oce has to also be set to the same settings.  but when i want to plot a half size set i have to go back to my windows settings for the oce and make sure the cut size and roll are correct and then plot again. but i cant go back to 24x36 without changing the windows plotter configuration again.  with autocad the pc3 controlled it all.
thanks for your help and insight
revit mep suite 2011
quad core, 8gb ram, 1gb video, 27" widescreen monitor
mech/elec/plum/fp
Setup PDF plotting in Revit
Fri, Apr 15, 2011 at 1:06:51 PM
Problem Plotting Drawing Title Bubbles
Thu, Nov 15, 2007 at 4:01:14 PM
Setting a project up to easily plot between different sheet sizes/plotters
Sun, Jul 18, 2021 at 10:22:33 AM
Multiple independent sheet index for cover sheet
Tue, Feb 4, 2014 at 8:28:13 AM
plotting / printing
Wed, Feb 13, 2008 at 8:31:12 AM
Page generation time: 1.8705
