Forums >> Revit Building >> Technical Support >> Kenoting a Membrane Layer (0" thickness)
Sat, Feb 12, 2011 at 12:23:27 PM | Kenoting a Membrane Layer (0" thickness)
boydj
I have searched the threads and wanted to confirm the following:
I have a standard wall assembly with the Vapor and Moisture Barrier, each with ZERO thickness.  I am unable to find a way to Keynote these layers with Keynote Material in a wall section or detail.  Keynote User does not seem very parametric or adaptable to future modifications.
From the threads it appears the only way to achieve this is by creating a Detail Line item Family and drawing the Zero Thickness Membrane Detail Family Line for each view where I want to keynote the membrane layer, and assign the correct Keynote.
Is this the only way to Keynote a Membrane Layer?
This method is not very Parametric and causes lineweight issues when drawn adjacent to the perimeter of a wall type (exterior limits are heavier lines).
thanks for any comments
Errors using Membrane Layer: zero / non-zero thickness
Wed, Aug 7, 2013 at 6:08:50 PM
Zero thickness wall layer
Mon, Mar 30, 2009 at 7:22:16 AM
What's the Point of the Membrane Layer
Mon, Nov 11, 2013 at 5:11:55 PM
How to control a single-layer wall?
Wed, Apr 28, 2010 at 2:39:50 AM
show Vapor Barrier below the foundation slab
Fri, Mar 15, 2013 at 11:12:17 AM
Page generation time: 5.8615
