Forums >> Revit Building >> Technical Support >> how to make a pecific railing?
Sat, Feb 12, 2011 at 12:05:43 AM | how to make a pecific railing?
fairywiner
I want to add railing to my project, the style I want to made is shown in the sketchup picture28 , and I use the railing command, railing is shown in the picture30, how can I make a special rail? Also when placed the railing on my wall on top of building, railing is just below the wall, not stand on the top of the wall,see my pictue29. how can I adjust it ?
沧海月明珠有泪
Sat, Feb 12, 2011 at 7:40:33 AM | how to make a pecific railing?
4 Stars: 205 Votes
Fairy, I told you before, read your HELP menu, learn how to search here in Forums, read the tutorials and I believe you need a "Basic Training" first.
Sun, Feb 13, 2011 at 2:25:56 AM | how to make a pecific railing?
fairywiner
Sorry, I have tried what you told me, almost every thing is ok, but I still can't make the baluster like what you have shown me, look at the stronger baluster at the end of my model, see picture1, how can I add the stronger baluster in the middle of my model in a set distance pattern just as what you have shown to me see picture3. I have studied the parameter from your picture, and I also made on my baluster parameter, I don't kown where is the problem. seen my picture2. Thank you.
沧海月明珠有泪
Sun, Feb 13, 2011 at 5:06:34 AM | how to make a pecific railing?
4 Stars: 205 Votes
You need to "Duplicate" a baluster in project browser (to create a new one - Stronger) like you can see in my first image, then you can duplicate more balusters and change the baluster/post like you can see in my second image, then is just a matter of playing/adjusting the distance between them.
Also, take a look at this: http://images.dcheetahimages.com/au.autodesk.com/ama/images/media/AB114-1.pdf
 http://au.autodesk.com/?nd=class&session_id=5380
Sun, Feb 13, 2011 at 7:11:56 AM | how to make a pecific railing?
fairywiner
ok, thank you, I have done it successfully. much appreciated!
沧海月明珠有泪
how to add some pecific pattern of the surface?
Sun, Feb 13, 2011 at 7:54:27 AM
Railing not shown in list
Mon, Jun 30, 2014 at 4:25:56 PM
how to make a good glass railing
Sat, Apr 6, 2019 at 1:37:56 PM
11
Railing at stair bottom!
Thu, Feb 28, 2008 at 10:57:33 AM
single wall railing
Thu, Feb 16, 2006 at 4:44:19 PM
Page generation time: 1.8483
