23 Users Online (21 Members):
Forums >> Revit Building >> Technical Support >> Can't get windows to cut through a mass created by dividing surfaces.
1 Posts No Rating |
I used a "Curtain Panel - Pattern Based" family to create the look of metal cladding. After applying it to a conceptual model with the divide surface command, I found that I couldn't simply drop in parametric windows on the conceptual mass as I would on a normal wall. What should I do?
" I found that I couldn't simply drop in parametric windows on the conceptual mass as I would on a normal wall." - Of course not, a Mass is a mass and a Wall is a Wall, what you can do is create another "Curtain Panel - Pattern Based" family like you need then load into your conceptual model and replace the panels you need.
So mass voids don't cut masses? |
Wed, Jun 1, 2016 at 6:45:45 PM
shaft through a wall created from a mass |
Tue, Mar 24, 2009 at 2:27:05 PM
cut mass |
Mon, Apr 27, 2015 at 9:50:59 AM
Mass Object Not Printing Correctly |
Thu, Feb 28, 2008 at 2:19:56 PM
Cutting a section through a mass |
Sat, May 16, 2020 at 4:21:54 AM
