Forums >> Revit Building >> Technical Support >> Moving the entire model in one file to match the other file
Fri, Feb 11, 2011 at 10:30:59 AM | Moving the entire model in one file to match the other file
diesellam
Hi,
I have 2 different files.  One is for Architectural and one is for Structural.
Currently, the entire Strucutural model is about 5 feet off of the Architectural model.
What's the best way to move the entire Structural model to match the Architectural model?
Wed, Feb 16, 2011 at 10:05:43 AM | Moving the entire model in one file to match the other file
tomdeplater
tomdeplater Avatar
1 Stars: 1 Votes
if you link the structural file into the architectural file, then you should be able to either in '3d view' or section select and move the whole model down.
after this you can bind the files together if you choose.
_tom
www.revittutorialsonline.com ::
Wed, Feb 16, 2011 at 10:59:30 AM | Moving the entire model in one file to match the other file
cadman6735
cadman6735 Avatar
5 Stars: 4 Votes
Open your structural file and acquire coordinates from the Arch link
this will but both files to the same 0,0,0 coord system
link any new files in using shared coordinates
always pin your links to avoind accidental movement of link files, at the bottom of your revit screen I suggest unchecking Press & Drag option...  That can be dangerouse tool.
If your models still don't line up, find a common base point such as a grid lind crossing and use ID point in your master model to get your coords and then open the linked model and use Specify at point to reassign the common point  in your other model to match coord point of your master model.
Sometimes, when links get moved or out of line it can be like a dog chasing its tail to realign the models but it is doable.
Moving links and/or models should be your last resort.
  • Ability is what you're capable of doing.
  • Motivation determines what you do.
  • Attitude determines how well you do it.
Quote by:  Holtz, Lou
  • Life is all about the attitude
Wed, Feb 16, 2011 at 11:09:57 AM | Moving the entire model in one file to match the other file
cadman6735
cadman6735 Avatar
5 Stars: 4 Votes
and I would suggest never moving a model, only move a link as a last resort.
My fingers got ahead of my brain...
I hope this helps
Wed, Feb 16, 2011 at 11:13:39 AM | Moving the entire model in one file to match the other file
cadman6735
cadman6735 Avatar
5 Stars: 4 Votes
and I meant to say use Specify coordinates at point, not ID point
I am getting my Acad and Revit terms mixed up, sorry
where is the freaking edit button for this forum?
found the edit button, hidden uder the number....
Edited on: Wed, Feb 16, 2011 at 11:14:20 AM
nudging or moving the entire piping system upward vertically
Fri, May 20, 2011 at 7:26:15 AM
Moving Toposurface. Imported from AutoCAD file.
Tue, May 12, 2015 at 7:24:19 AM
Moving an entire plan
Mon, Oct 29, 2012 at 7:31:51 AM
Moving a linked Revit model
Thu, Nov 21, 2013 at 3:57:59 PM
Importing a cad file
Fri, Apr 27, 2012 at 3:33:21 PM
Page generation time: 1.6303
