Forums >> Revit Building >> Technical Support >> how to add some pecific pattern of the surface?
Fri, Feb 11, 2011 at 12:57:23 AM | how to add some pecific pattern of the surface?
fairywiner
I want to add some pecific pattern, can I draw a pattern in CADand then load it into the project. also I need to know the scale of the patter. see my picture17
Because I need to draw elevation details and to show how the bricks or  stone materils arrange on the elevation. see the arrange of the briks in cad picture18
沧海月明珠有泪
Fri, Feb 11, 2011 at 4:01:08 AM | how to add some pecific pattern of the surface?
4 Stars: 205 Votes
There are lots of threads about this same question in Forum, search for "Hatch patterns" and you will see lots of them.
Here you have one example: http://www.revitcity.com/forums.php?action=viewthread&thread_id=21478
Now if you look at the bottom of that link you will see similar threads, just search and read, you must learn how to use this site.
Fri, Feb 11, 2011 at 10:16:52 PM | how to add some pecific pattern of the surface?
fairywiner
I have read the site and help files. and I know where to chagne the pattern. but when I load my own patterns, see picture27, the revit jump out the problem see picture24. I want to make a metric pattern see picture25, and I modeled on the the pat files which I found on net. it is my pat files . can you tell me how to edit the pattern files, thank you!
this is my patterns
;%VERSION=3.0
;%UNITS=MM
*VHUGOMG,Revitcity
;%TYPE=MODEL
0,             0,             0,             0,             60090,            0,             0,             750,             750,            600,             -600
沧海月明珠有泪
Sat, Feb 12, 2011 at 6:20:05 AM | how to add some pecific pattern of the surface?
4 Stars: 205 Votes
There are two kinds of "Pattern Types" - "Model" and "Drafting" do you know the difference between the two? look at my first image (directly from your HELP menu)
Look at your "Image 24" ---> "No Drafting type  patterns found", now look what you post:
"this is my patterns
;%VERSION=3.0
;%UNITS=MM
*VHUGOMG,Revitcity
;%TYPE=MODEL
0,             0,             0,             0,             60090,            0,             0,             750,             750,            600,             -600"
Can you see the difference??? Yes? No? well, this is the difference ";%TYPE=MODEL", you are trying to create a "DRAFTING" pattern with a "MODEL" patter, you need to change that "Model to Drafting".
How can you edit that pattern to change that? I told you before "...just search and read, you must learn how to use this site"....
Just open that PAT file with a "notepad", change that and save, that's it, AGAIN, look at my second image.... Your HELP menu is your BEST TUTORIAL.
Edited on: Sat, Feb 12, 2011 at 6:21:12 AM
Sun, Feb 13, 2011 at 7:54:27 AM | how to add some pecific pattern of the surface?
hugh
3.5 Stars: 4 Votes
You need make one small change:
;%VERSION=3.0
;%UNITS=MM
*VHUGOMG,Revitcity
;%TYPE=MODEL
0,             0,             0,             0,             600
90,            0,             0,             600,             750,            600,             -600
hth,
Hugh Adamson
www.hatchkit.com.au
Surface pattern
Mon, Sep 10, 2007 at 11:18:01 AM
Surface pattern move/align/adjust problems [ 1 2 ]
Thu, Sep 17, 2020 at 10:29:33 AM
19
SURFACE PATTERN LINE WEIGHT
Fri, Mar 28, 2014 at 2:30:00 PM
voronoi surface pattern
Fri, Jun 24, 2011 at 2:14:03 PM
Surface pattern problem
Tue, May 18, 2010 at 9:15:56 AM
Page generation time: 1.0438
