Forums >> Revit Building >> Technical Support >> Pinning all walls at once
Thu, Feb 10, 2011 at 7:41:25 AM | Pinning all walls at once
fricharz
I have a large building footprint with a lot of in's and out's of wall projections.  Is there a way to pin all of these walls at once, so they do not move?
Thu, Feb 10, 2011 at 10:01:51 AM | Pinning all walls at once
Pinning all walls would not be good.  It is far better to learn good Revit practice rather than overloading your project with pinned elements.
Thu, Feb 10, 2011 at 2:34:10 PM | Pinning all walls at once
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
This is still a risk of over-constraining... but if you lay out a good, dimensioned grid, you can pin the grid, and then keep your walls on, or aligned and locked to it.  locking too many elements will cause you a lot of grief, but major walls tend to not hurt too much.  best way to get the lock icon/option to appear is using the align tool.  Even if you're aligning to a line/plane an object is already on, the icon will reappear.
Walls keep moving
Fri, Apr 11, 2008 at 10:04:17 AM
overlaying viewports on sheet?
Thu, Apr 16, 2009 at 11:13:17 PM
Locking and pinning the revit link
Thu, May 6, 2010 at 8:20:24 AM
pinning text to elements??
Wed, Aug 20, 2008 at 4:30:00 PM
I hate the Revit Automatic Wall joins
Thu, Oct 25, 2007 at 9:51:27 AM
Page generation time: 0.4708
