Forums >> Revit Building >> Technical Support >> how to cut the wall along the roof?
Thu, Feb 10, 2011 at 2:28:09 AM | how to cut the wall along the roof?
fairywiner
look, I made a tower of the building, and the wall of tower is higher than the roof , how to cut the wall along the roof? I have known the attatch command, but it only delete the upper wall of the roof, I want to delete the wall below the roof.
沧海月明珠有泪
Thu, Feb 10, 2011 at 4:53:47 AM | how to cut the wall along the roof?
4 Stars: 205 Votes
This question is a little unclear to me, you say: "how to cut the wall along the roof? I have known the attatch command, but it only delete the upper wall of the roof, I want to delete the wall below the roof." this not clear and by the way, when you select a wall you attach the TOP and the BASE of that wall, just look at your ribbon after you click on "attach wall" button.
Thu, Feb 10, 2011 at 5:03:32 AM | how to cut the wall along the roof?
jonezy
i think you mean to stop the roof running into the wall, for this you could use an opening by face to get the roof to stop were you want it too...
Thu, Feb 10, 2011 at 5:59:01 AM | how to cut the wall along the roof?
4 Stars: 205 Votes
"i think you mean to stop the roof running into the wall, for this you could use an opening by face to get the roof to stop were you want it too..." - Well, if this is what he want I think I use the "Vertical Opening", with this way the opening is perpendicular to a level and not a face.
Let see what he really want...
Thu, Feb 10, 2011 at 6:02:43 AM | how to cut the wall along the roof?
jonezy
yes T, that way works just as well... which ever takes your fancy FW
Thu, Feb 10, 2011 at 8:41:15 PM | how to cut the wall along the roof?
fairywiner
sorry, what I mean is that to see my picture12, the hightlight bule wall is what I want to revised. Actually if I hide the roof the wall would be look like the picture13. What I want is that I want to cut the wall under the roof.
is that to edit profile of wall in elevation? see my picture15
Edited on: Thu, Feb 10, 2011 at 9:10:14 PM
沧海月明珠有泪
Fri, Feb 11, 2011 at 2:29:58 AM | how to cut the wall along the roof?
jonezy
ah, right, yes edit the wall profile in elevation to remove the bit you dont need
Roof/wall join: Cut roof
Tue, Apr 27, 2010 at 7:53:13 AM
Cut roof with wall sweep when join
Thu, Jan 17, 2019 at 6:47:34 AM
Wall Sweep ending at roof slope/roof line
Wed, Nov 21, 2007 at 11:07:34 PM
cut roof geomentry by a wall or another
Mon, Sep 28, 2009 at 3:52:53 PM
window not cutting joined roof
Mon, Mar 6, 2017 at 4:23:50 PM
Page generation time: 3.0758
