Forums >> Revit Building >> Technical Support >> MASSING IN REVIT
Wed, Feb 9, 2011 at 2:46:48 PM | MASSING IN REVIT
kiknchikn
Does anyone know why Autodesk took the old massing tools out and replaced it with the junk in Revit 2011? I'm losing my faith with Autodesk and Revit. It was fine just the way it was in 2010. Remember the old saying "Don't reinvent the wheel"
Thu, Feb 10, 2011 at 3:43:50 AM | MASSING IN REVIT
4 Stars: 205 Votes
"Does anyone know why Autodesk took the old massing tools out and replaced it with the junk in Revit 2011?" - What are you talking about? Autodesk didn't removed anything, if you want to create a "Mass" look at your ribbon, you will see "Massing and site", here you can create Masses, if you want the OLD "In-Place" go to "Home > Component > Model In-Place"
Mon, Aug 8, 2011 at 9:24:38 AM | MASSING IN REVIT
saransh
hi friends i am using revit 2009 can any 1 please tell me is it possible to do good massing work in it?????or i need 2010 only?
Mon, Aug 8, 2011 at 9:33:28 AM | MASSING IN REVIT
You can create mass in any version of Revit but the tools were significantly improved in 2011.... May have been 2010.
Tue, Aug 9, 2011 at 2:18:56 PM | MASSING IN REVIT
saransh
right now i am learning on 2009 .....so will it possible for me to learn advanced massing on 2011 on myself or again i  have to join classes for 2011 please tell me.
why my massing can't not be a solid?
Fri, Feb 11, 2011 at 8:26:42 PM
Finding Massing Model
Wed, Feb 23, 2011 at 3:54:53 PM
>>>stuck with creating massing form in revit<<< HELP!
Fri, Nov 6, 2009 at 4:07:53 PM
Massing Tutorials (Revit Architecture 2013)
Thu, Sep 13, 2012 at 4:17:47 AM
Massing
Mon, Jun 22, 2009 at 9:18:46 AM
Page generation time: 1.2811
