Forums >> Revit Building >> Technical Support >> Check Mark and Worksets
Wed, Feb 9, 2011 at 2:22:19 PM | Check Mark and Worksets
dumbstuff
I have made a Check Mark (to indicate a task is done) as an annotation so that I can place it in any view and on sheets.  Problem is, I would love for them to be in a Workset so that I can turn them off universally.  Any thoughts how this can be done or a work around? Thanks
Wed, Feb 9, 2011 at 3:33:38 PM | Check Mark and Worksets
If in the annotation family you create a new sub-category - all linework can be in that sub-category and that can be turned off in VG.  CAUTION - You can not place text in a sub-category.
Wed, Feb 9, 2011 at 6:21:46 PM | Check Mark and Worksets
dumbstuff
Thank you, that worked for the lines in the tag but not so well for the filled region.  I actually found a way around it though, I used a Yes/No parameter to turn the object elements on or off and in my families list I can simple set it project wide.
Worksets- Borrowing vs. checking out
Wed, Sep 3, 2008 at 9:49:06 AM
Cant Delete one of My worksets...please help
Thu, Feb 14, 2019 at 1:48:12 PM
13
cannot enable worksets
Tue, Jan 23, 2018 at 11:00:18 AM
13
WORKSET - problem moving elements to the appropriate worksets PLEASE HELP
Wed, Feb 1, 2012 at 5:04:15 PM
window schedule by mark and count
Wed, Jun 4, 2014 at 2:31:52 PM
Page generation time: 0.2129
