Forums >> Revit Building >> Technical Support >> why my massing can't not be a solid?
Wed, Feb 9, 2011 at 5:09:46 AM | why my massing can't not be a solid?
fairywiner
look, I want to make a massing according to my cad footprint, but when I finished the mass, it can not be a solid body, just mesh, the cubic which I draw on the right side of my massing is ok, it is a solid. Did I do somthing wrong when I make the massing or the frofile of my massing is to comlicated so as to it can not become a solid body?
picture2 is my sketchup model about the building.
沧海月明珠有泪
Wed, Feb 9, 2011 at 6:18:24 AM | why my massing can't not be a solid?
4 Stars: 205 Votes
How do you create that "Mass"? with "Massing and Site" or with a "Create In-Place" in the category Mass?
Is that a "Closed Loop" like a "polyline" in CAD?
May I ask you why are you creating that with mass when you can draw Walls directly on your project?
Wed, Feb 9, 2011 at 9:34:59 PM | why my massing can't not be a solid?
fairywiner
I create the mass first I click  Massing and Site and then I click In-place mass then there jump out an dialog,  I give the give name mass1,  then I use pick lines, after I picked all the profile line, I use trim tool to make sure they can be a closed line. Then I selected the colosed poly line, click creat form tab, pick the form tab ,then it become the massing. but the massing is not a solid body , only a mesh body. And I make an other try with the same method, but just to draw a rectangle and then click creat form tab, pick the form tab, it became an solid cubic. So I don't the what's the difference bettween the two massing. Only one difference I found is that one is simple rectangle and the other is complex polyline in their footprint.
The reason why I made massing istead of drawing walls directly is that I want to fist make a massing of the building, because the elevation of my building is little complicated, so I think it's better to make a massing frame, then I can use the command model by faces to generate the walls. I use this mothed is also because the tutorial files I leart tells me to generate a building's wall from pick the faces of a already made massing. The turtorial fiel I have aslo attached to my thread. The method is taught on page 107 of the pdf. I don't know if it is a good method to make a building.
This is my first revit products, and I want to finish my design with revit.
沧海月明珠有泪
Thu, Feb 10, 2011 at 5:13:08 AM | why my massing can't not be a solid?
4 Stars: 205 Votes
Your process is correct and if you need first to create a "Mass Studie" you are right to do that, you said: "...then I use pick lines, after I picked all the profile line, I use trim tool to make sure they can be a closed line." - If you used the "Trim" tool on all lines should work.... Wierd...
Can you please upload here that "Mass/Mesh" so we can take a look?
Thu, Feb 10, 2011 at 8:58:17 PM | Typhoon
fairywiner
I just tried more times and evreything is done. Thank you.
沧海月明珠有泪
Fri, Feb 11, 2011 at 3:41:55 AM | why my massing can't not be a solid?
4 Stars: 205 Votes
And how you solved the problem? It wasn't a "Closed Polyline" right?
Fri, Feb 11, 2011 at 8:26:42 PM | why my massing can't not be a solid?
fairywiner
I don't know how I solved the problem, because I use the same method to draw a massing, But I think the only one difference is that previous footprint line is not closed well, I can't pick all the segment of the line by one click, the latter footprint line can be picked all the segement by one click. I think may be that's the problem.
沧海月明珠有泪
Tapered cantilevered beam with openings
Mon, Aug 14, 2006 at 5:06:16 AM
Massing Printing Problem-solve (sort of)-Revit Architecture (2008)
Fri, Aug 24, 2007 at 3:15:20 PM
Solid Extrusion Question
Wed, Aug 2, 2006 at 9:32:08 AM
Editing Solid Extrusions
Sun, Jul 30, 2006 at 9:00:52 PM
Creating a cupola
Tue, May 13, 2008 at 2:33:17 PM
Page generation time: 2.0316
