Forums >> Revit Building >> Technical Support >> Problems with display of a recently created family
Tue, Feb 8, 2011 at 5:06:33 PM | Problems with display of a recently created family
Diggerdon2
I have just created a new column family [architectural - no structural constraints] - I created the family using a Revit Metric Template base - set up the columns length and width with ref planes and left its lower and upper level elevational ref planes in place. I have successfully imported the new column family into my project - placed the columns BUT WHEN I TRY TO ATTACH THE COLUMNS TO THE SLOPING ROOF THEY DO NOT EXTEND VISUALLY -NNB Instance Properties says they are attached and give a value to the increase in length/height of the columns that varies depending on where the column hits the sloping roof. WHY ARE THE COLUMNS NOT VISUALLY EXTENDING TO THE ROOF? This occurrs in all elevational type views ie: section/elevations and 3D.
Wed, Feb 9, 2011 at 7:31:37 AM | Problems with display of a recently created family
Your extrusion is set to a fixed length, if you look at the stock columns, they go level to level.
Thu, Feb 10, 2011 at 8:56:43 AM | Problems with display of a recently created family
Diggerdon2
Thanks - I have extended the column so it is touching both LEVELS in Elevation Views [I assume that is what you mean by 'my' column being set to a fixed length?] and I have also added two new parameters OFFSET TOP and OFFSET BASE as per the Custom 150mm Diameter Round Column. These are grouped under DIMENSIONS and their Type is LENGTH. The value for both parameters has been set to 0.00.  I have reloaded the family into the project and overridden the existing family. Unfortunately the column extends but still does not display visually as having done so.
I am missing a trick or the bleeding obvious??
Thanks again for your response
Thu, Feb 10, 2011 at 11:26:27 AM | Problems with display of a recently created family
Although I am a firm believer in learning how to use Revit, sometimes you are better off to start with something that works and modify that.  Does a stock concrete structural column work?  If so, open that family, save it to a new name, edilt the profile of the solid to your shape and change the material.  DONE!
Don't mess with anything else and don't delete the solid - just edit the profile sketch!
Thu, Feb 10, 2011 at 1:04:04 PM | Problems with display of a recently created family
pchan
pchan Avatar
5 Stars: 5 Votes
First off, the offset top and offset base value inside your family are useless since you didn't associate any parameters inside your column family.
Second, there is a system "instant parameter" for column family where you can change the offset (for top and base) value in the project environment.
Also, under the properties for the column family inside the project, there is "field" called "attachment justification" under construction, if you choose "Intersect Column Midline", that might get you what you need to do to attach to the roof ...
HTH
Philip
Revit 2009 Video Display Problems
Thu, Jan 13, 2011 at 1:02:38 PM
Filled Region display order
Tue, Jan 26, 2010 at 12:29:57 PM
IN PLACE FAMILY PROBLEMS
Tue, May 12, 2009 at 5:29:50 PM
Family problems
Thu, Oct 24, 2013 at 3:11:37 PM
14
Light Fixture Family problems
Wed, Jun 13, 2012 at 3:25:52 AM
Page generation time: 1.9543
