Forums >> Revit Structure >> Technical Support >> Deactivate Analytical Truss and Slab
Tue, Feb 8, 2011 at 12:57:32 PM | Deactivate Analytical Truss and Slab
littleguru
Is there a way to turn off the analytical lines for a truss and a slab?  I have some that are in the model for section puposes only.  I do not want the members to transfer form REVIT to the analysis software.
I know that beams can be turned off by going through Properties > Structural Analysis > Analyze As > and selecting "NOT FOR ANALYSIS".
Walls can be turned off by > Properties > Analytical Model > UNCHECK "ENABLE ANALYTICAL MODEL"
I cannot find a way to do this for truss families and slabs.  I am updating the RISA analysis model constantly from REVIT so this needs to be an efficient process.
Thanks
Tue, Feb 8, 2011 at 1:22:19 PM | Deactivate Analytical Truss and Slab
I know that I can turn these off in VG settings.
Wed, Feb 9, 2011 at 8:10:56 AM | Deactivate Analytical Truss and Slab
littleguru
I figured it out.  This was for a cold form roof truss, but others should be similar.
1: Hover over truss and Tab to select individual member of truss family.
2: Unpin the member
3: Under Properties > Structural Analysis > Change Analyze As from "lateral" to "Not for Analysis"
4: Pin the members.
Trick - when selecting one member do a "select all instances" to spped up the process.
Steel bar truss girder slab deck
Thu, Oct 16, 2014 at 11:17:49 AM
Analytical Lines creates blank space in schedule in revit str 2014
Thu, Sep 11, 2014 at 8:10:30 AM
Adjusting the analytical line in a revit family
Fri, Mar 5, 2010 at 9:16:30 AM
Creating a structural slab for analysis
Tue, Jun 5, 2007 at 5:08:16 AM
Truss overhang help
Wed, May 23, 2012 at 8:32:23 AM
Page generation time: 0.3399
