Forums >> Community >> Newbies >> Stumped on why window selection or crossing selection wont pick pipe fittings ?
Mon, Feb 7, 2011 at 11:33:09 AM | Stumped on why window selection or crossing selection wont pick pipe fittings ?
DaveB440
Hi everyone,
  Can anyone help !   When I select anything with a window or by crossing it and then using the filter my pipe fittings are never selected.  I can pick each fitting individually only.  I have set my detail level to course, medium and fine with the same results.  You can see my problem if I have to pick a few hundred pipe fittings individually.  Pipe work is not pinned.  Setting ?  I am using REVIT MEP 2011.
Thanks for any help,  Dave.
Mon, Feb 7, 2011 at 12:54:55 PM | Stumped on why window selection or crossing selection wont pick pipe fittings ?
Thread Post Kudo! #2
DaveB440
Answered my own ?  View Range.
Fri, Feb 8, 2013 at 11:25:53 AM | Stumped on why window selection or crossing selection wont pick pipe fittings ?
CadMasterAdam
that did it for a coworker also!
good idea
Mon, Nov 7, 2016 at 11:08:59 AM | Stumped on why window selection or crossing selection wont pick pipe fittings ?
jacksobp
jacksobp Avatar
5 Stars: 3 Votes
Thank you for posting your solution...that had me confused for quite awhile.
Sat, Jun 1, 2024 at 1:44:16 PM | Stumped on why window selection or crossing selection wont pick pipe fittings ?
Cranile
can't believe after 16 years this still help. Somehow it worked when i changed my VR to 90cm, then change it back to 120cm.
My problem was i cannot select my toilet with window selection, i have to select them individually. Such a pain
polyline selection window
Sat, Feb 6, 2016 at 7:57:07 AM
selection issue
Fri, Mar 4, 2005 at 3:43:11 PM
selection window grabs wrong items
Thu, Jul 19, 2012 at 3:05:37 PM
How to find the missing void object in family
Mon, Apr 21, 2008 at 12:54:48 PM
locking a plan in place?
Wed, Sep 26, 2007 at 3:40:43 PM
Page generation time: 0.3875
