Forums >> Revit Systems >> Technical Support >> Plumbing Risers connecting to mains
Mon, Feb 7, 2011 at 9:43:07 AM | Plumbing Risers connecting to mains
Eaganman
I have 12 years of AutoCad plumbing design experience and 1 year of Bently Plant/Pipe experience. I cannot figure out how to draw plumbing mains (ie, hot water, cold water and sanitary sewer mains) nor how to show risers connecting in the first floor ceiling. I would appreciate any recommendations on websites, videos, books, etc., which give some simple explanations on how to layout plumbing in Revit.
Mon, Feb 7, 2011 at 1:50:04 PM | Plumbing Risers connecting to mains
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
you have much more experience than I do at plumbing design, I have found that in revit you will need many workplanes. you must name the work planes and then you will be able to use the view framing elevation which will look directly at your view. you must also load fittings and pipe from the libraries. if your building is not been rotated you should be able to get automatic connections, the one that I am working on now has been rotated so the automatic connections do not seem to work well. hope this helps a little.
Mon, Feb 7, 2011 at 1:53:19 PM | Plumbing Risers connecting to mains
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
check out you tube and your help files, http://tinyurl.com/4vzp7tm
Plumbing Risers
Tue, May 29, 2007 at 12:54:12 PM
Inter connecting REVIT LINKS
Mon, Feb 20, 2012 at 3:22:55 AM
Connecting walls to stringers / hiding treads and risers
Thu, Nov 18, 2004 at 1:20:38 PM
Panelboard Schedule Not linking Mains and Mounting Parameters Rvit MEP 2013
Mon, Jun 10, 2013 at 3:02:54 PM
Plumbing riser help on a 14 story apartment building
Fri, Jul 26, 2013 at 2:13:42 PM
Page generation time: 0.0553
