Forums >> Revit Building >> Technical Support >> edit wall profile... what?
Mon, Feb 7, 2011 at 1:16:05 AM | edit wall profile... what?
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Okay, this is a fun one.   Revit 2011 64bit
I've lost the ability to edit some (but not all)  of my wall profiles.   "Reset profile" is my only option now, and I think i'd rather pass.  Curiously though, after I select one of the offending walls, both edit and reset buttons are initially available, but a fraction of a second later the "edit profile" button grays out.
no exaggeration--a quarter of a second later it grays out.  Now, since I have catlike reflexes, I can position the wall right below the edit profile button and select the wall and then click the button extremely fast, and sometimes I can do it in time, and YES, THE WALL IS EDITABLE.   I can make my changes, and finish the sketch, everything modifies and is copacetic.
So why is revit tweaking out?  It's graying out a common action, that I can even trick it into performing.  It's killing me.  Suggestions?  Seen this before?
Mon, Feb 7, 2011 at 1:58:19 PM | edit wall profile... what?
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
I haven't had that before but I did run into "walls suddenly transparent" which is to say that all the fixtures on  the otherside of the wall were visible in exterior elevation and it did not matter VG settings cause all were tried. Revit is a wondermint.
Edit profile on a curved wall
Sun, Aug 29, 2010 at 11:30:00 PM
Curtain wall profile edit
Thu, Sep 19, 2013 at 11:40:01 AM
Foundation Wall Profile
Tue, Feb 16, 2016 at 4:35:07 AM
Intersecting shapes in Wall edit profile (revit 2012)
Sun, Nov 10, 2013 at 8:42:11 PM
edit curved wall profile (Really need help!)
Tue, Oct 9, 2007 at 7:32:03 PM
Page generation time: 1.1985
