Forums >> Revit Building >> Technical Support >> Simple Metal Roof Truss - Revit Arch 2010
Fri, Feb 4, 2011 at 7:23:59 AM | Simple Metal Roof Truss - Revit Arch 2010
dstartari
Hi All,
 We are trying to create new steel roof truss families for a project that is currently under construction. We intend to build about 20 trusses in total. We could use your expert advice on two things:
  • Is the family editor in revit 2010 (Architecture) able to clean junctions, similar to the 'Beam / Column Joins' in the project editor? We started with a 'Metric Structural Framing - Complex and Trusses family' and used standard steel sections to create the truss. However, we have been unable to clean the joins.
  • Is is better to construct the individual trusses as individual familes or just model in place in the project. What would be less heavy on the model? Please note that the majority of the trusses are unique in design.
I have attached our un-finished truss family for your information.
We are all pretty novice at this, and appreciate any advice.
Thanks
Daniel
METAL STUD ROOF TRUSS
Sat, Jun 28, 2008 at 6:22:20 AM
Can't see Truss under roof
Tue, Feb 16, 2010 at 4:29:05 PM
Roof Truss
Thu, Dec 13, 2007 at 3:20:16 PM
Hip roof Truss
Fri, Nov 10, 2006 at 10:18:49 AM
Revit roof... truss vs. rafter
Wed, Dec 18, 2013 at 11:26:22 AM
Page generation time: 1.7720
