Forums >> Revit Building >> Technical Support >> Performance lag with Type Selector
Fri, Feb 4, 2011 at 7:04:55 AM | Performance lag with Type Selector
Dgodfrey
4 Stars: 4 Votes
Using Revit 2010 and recently noticed a long delay when accessing the type selector pull down. The first few times seem normal but then it starts to take longer and longer (30 seconds or more) and eventually it just stalls out with no action. Any suggestions of why this might be happening?
Fri, Feb 4, 2011 at 8:33:07 AM | Performance lag with Type Selector
Are you talking about a family type or the family selection?
How many families do you have loaded in your project?  How many of those should be purged?
Fri, Feb 4, 2011 at 8:48:11 AM | Performance lag with Type Selector
Dgodfrey
4 Stars: 4 Votes
It's the individual Elements of the family. e.g. If I want to swap out one size window for another, it churns for a long time. If I swap it using the Element Properties, it's fine. I will purge some families and see if it's noticable. It just started doing this without a lot of warning and every file seems to have the problem.
Fri, Feb 4, 2011 at 9:04:47 AM | Performance lag with Type Selector
Are these windows in groups?  If so, then that is your answer
Fri, Feb 4, 2011 at 9:26:07 AM | Performance lag with Type Selector
Dgodfrey
4 Stars: 4 Votes
No they're not and it's not just windows, that was just an example. It's anytime I open the type selection drop down.
TYPE SELECTOR for ramps and stairs
Thu, May 3, 2007 at 2:46:53 AM
loaded families not visible in type selector
Sun, May 3, 2009 at 1:30:04 PM
FAMILY APPEARING IN TYPE SELECTOR
Sun, Apr 28, 2013 at 7:36:29 AM
Type Selector problems
Wed, Apr 10, 2013 at 6:35:58 AM
Additional, simplified type selector box has appeared on my toolbar ?
Thu, Oct 29, 2009 at 5:33:40 PM
Page generation time: 0.5500
