30 Users Online (28 Members):
Forums >> Revit Structure >> Tips & Tricks >> tapered beam
12 Posts No Rating |
I'm trying to build a tapered canopy beam for a project and I'm having trouble getting the 2 tapered sections to work paramtricly. I'm fairly new to revit so I'm in the learning mode. I can adjust the flange width and the depth buut for some reason the tapered length is giving me fits. If anyone can help me it is appreciated.
5 Posts No Rating |
I do not see section profiles in your family, you may need to define a profile for each end of each sweep blend you use. this should allow you to flex your beam for other lengths. see attached profile
Hello,
Not sure if you fixed it yet, but see if this works for you.
Concrete tapered beam |
Wed, Jul 3, 2013 at 12:05:46 PM
Tapered HSS beam - in need of |
Wed, Feb 26, 2014 at 8:57:46 AM
Tapered cantilevered beam with openings |
Mon, Aug 14, 2006 at 5:06:16 AM
Tapered Beams |
Thu, Nov 4, 2010 at 12:53:49 PM
Tapered beams |
Thu, Mar 22, 2007 at 2:05:54 PM
