Forums >> Revit Building >> Technical Support >> Can Revit's Mental Ray use a HDRI style environment for exterior reflections?
Thu, Feb 3, 2011 at 10:04:07 AM | Can Revit's Mental Ray use a HDRI style environment for exterior reflections?
rustammarc
Hi All
Generally impressed with Revit Mental Ray, which I'm using in RAC2009 and 2010.
Glass looks great on interior views where it has something to reflect.   Looks flat on exteriors since I do not have any context buildings modeled and do not plan to.  Is there a way to add an "environment" jpg or HDRI that will reflect in the glass?  I'm not talking about a background bitmap "sky", just something to reflect on the glass.
Thanks
Thu, Feb 3, 2011 at 1:27:34 PM | Can Revit's Mental Ray use a HDRI style environment for exterior reflections?
4 Stars: 205 Votes
Something like this? place a "Decal" like you can see in my second image and turn on the "Reflectance" in your glass material.
HTH
Tue, Jun 11, 2013 at 10:41:11 AM | Can Revit's Mental Ray use a HDRI style environment for exterior reflections?
westdy
I have tried this but the position of my camera is much further from the building, when i but the decal on the wall that is about 30ft high, the wall ends up casting a shadow because the sun is located somewhere behind me to brighten up the front of the building. Ive tried putting a line of trees behind the camera to break up the reflect horizon line on the first floor, but they dont seem to appear, an ideas? Id like to keep the camera angle, as i alredy have different angles like the one in the previously posted picture.
*Revit 2013
Wed, Jun 12, 2013 at 8:39:36 AM | Can Revit's Mental Ray use a HDRI style environment for exterior reflections?
westdy
Tried the decal wall but placed it back alot further, used a higher setting, and heres what happened...
Theres a clear black square in the reflection which means I need to make this wall huge, but then it affects my sunlight. So i figured a simple solution was to use trees to break up that white horizon line, but they dont appear. Ive placeed them at ground level and +10' above and nothing. Why dont they show up?
Revit's Mental Ray issues
Mon, Jul 21, 2008 at 6:37:57 AM
Mental Ray rendering questions
Mon, Oct 13, 2008 at 12:37:55 PM
I hate RPC people images. Anyone got tips on how to make my own in Mental Ray?
Thu, Jan 1, 2009 at 12:33:39 AM
mental ray compatible garage door?
Thu, Sep 18, 2008 at 10:16:00 AM
Rendering-Background Image-I don't find that option in Mental Ray
Fri, Jun 20, 2008 at 10:42:00 AM
Page generation time: 1.6508
