20 Users Online (18 Members):
Forums >> Revit Building >> Technical Support >> Painting Wall Corners in Groups Issue
Hey, So I'm having an problem trying to "paint" these bays. As you can see in the image below, these are modeled groups I've created and the only way I can change the color is to edit the group and paint them. The issue is that when I finish and close out the group, only the group instance that I edited has the painted corner on the side, while the rest don't. Is there a fix for this?
----------------------------------- Thehiddenthought |
Not sure why you are painting a corner... wall joins should have taken care of that. Sometimes it is better to split a wall vertically and have tow different walls - each with a different exterior finish.
wall corners to automatically create extrusion |
Tue, Nov 28, 2017 at 8:30:09 AM
Split Facing and Painting both sides of a wall? |
Fri, Jan 13, 2017 at 10:52:50 PM
Wall joins (or wall corners) |
Sun, Nov 18, 2012 at 10:40:59 PM
Curtain wall corners |
Sat, Apr 5, 2008 at 12:45:04 AM
painting schedule |
Tue, Jun 25, 2013 at 7:27:08 AM
