26 Users Online (24 Members):
Forums >> Revit Building >> Technical Support >> Copy/Monitor Grids - can the edges move?
31 Posts No Rating |
Can anyone tell me if I use Copy/Monitor for Grids from the structural model into my architectural model if the monitor function will be broken if I want to control the end points of the grids. My attempt is to have all grids run by structural but the ends of the bubbles controllable in the different disciple models. So if structural makes a change the grids can be parametrically updated however where the bubbles lie still individual controled per revit model. Can suggestions? Thanks!
Two comments: - When you copy monitor, you then have your own COPY... which obviously you can modify and your consultant will receive an alert if you alter.
- There are two ways to alter grid extents - model (3D) and view (2d). So if you do C/M and only alter 2D,your consultant will not be notified.
Got ya. Thanks that makes sense
Can't Get Copy Monitor to Work for Grids and Levels |
Fri, Feb 21, 2014 at 4:55:28 PM
Copy Monitor Grids |
Tue, Feb 3, 2015 at 8:20:16 AM
Copy/monitor problems |
Wed, Apr 26, 2006 at 11:56:48 AM
Copy/Monitor Lights to Revit Architecture 2012 |
Wed, Oct 17, 2012 at 3:05:52 PM
Rev Arch 2009 conultants elelments in copy monitor |
Wed, Aug 31, 2011 at 2:21:36 PM
