15 Users Online (13 Members):
Forums >> General Discussion >> Wishlist >> ICF Construction walls needed
1 Posts No Rating |
Has anyone developed ICF wall type plug-ins?
What are you looking for, a block assembled wall ? I just create a a full height 8" or ? concrete core wall with rigid insul. on both sides. If you want it to appear as blocks in elevation you could create a pattern to suite.
If you really want blocks one method would be to use families created from a generic template. I will attach some below if you want to mess with them. They contain a core visability parameter to turn off the concrete, as in the real world the core would be a solid poured wall that you could make as a standard concrete wall. I also added cut instance parameters so you can cut around openings and up to corners.
Not sure why you need to go to this much detail though.
Post edited on 2005-11-06 00:17:08
ICF Block Family
EDIT: added cut parameters on the one in the next post.
Post edited on 2005-11-06 00:18:18
With Cut Parameters
You'll need corners, here's a 90 deg corner. If you keep moving forward with this and need 45 deg or others and need help creating them let me know.
EDIT: I just noticed the Height parameter ended up in th Electrical category, you can modify the parameter and place it in dimensions or ?.
Post edited on 2005-11-06 00:40:16
Steel beam connection to ICF walls |
Wed, Apr 13, 2016 at 9:30:53 AM
Core Slab and ICF |
Tue, Apr 5, 2005 at 10:34:16 AM
ICF and wall aligment |
Sat, Oct 8, 2016 at 11:55:35 AM
New Construction phase cuts Existing Phase |
Tue, Aug 9, 2011 at 12:21:57 PM
New Construction Wall showing up Black on exterior |
Tue, Jan 24, 2012 at 3:50:50 PM
