Forums >> Revit Building >> Technical Support >> Problem with Realist view style graphics
Wed, Feb 2, 2011 at 7:48:34 AM | Problem with Realist view style graphics
vareddirt
I have windows and doors that have the wall materials bleading through the trim when i use the realistic view style.  Is this a graphics card issue?? or is there something I can do to remedy this??  See pictures below of what the window should look like and what a few of the windows look like (it is doing it with doors as well).
Thanks!
Wed, Feb 2, 2011 at 8:14:43 AM | Problem with Realist view style graphics
DeifyMe
4 Stars: 2 Votes
is it just me or does it look like the windows aren't parralel with the wall face? is the window crooked and slightly recessed into the wall on the one side.
Wed, Feb 2, 2011 at 8:28:13 AM | Problem with Realist view style graphics
You are correct DeifyMe, something is terribly wrong with this family because it is at an angle with the wall.
Wed, Feb 2, 2011 at 8:38:56 AM | Problem with Realist view style graphics
vareddirt
That was my first thought as well, and upon further research this is not the case!  In the elevation view with realistic on the windows are fine, but in a 3d camera view, some of the windows and even some of the doors are doing this... oh as well as a cast stone window header that was put in.  This is the first time I have used the new realistic view setting and I  really like it for quick views, but I do not like this problem.
Wed, Feb 2, 2011 at 8:47:10 AM | Problem with Realist view style graphics
vareddirt
Here are the same 4 windows, one in regular 3d view, the other in 3d cameral view.
Edited on: Wed, Feb 2, 2011 at 8:50:01 AMEdited on: Wed, Feb 2, 2011 at 8:52:53 AMEdited on: Wed, Feb 2, 2011 at 8:53:52 AMEdited on: Wed, Feb 2, 2011 at 8:54:38 AMEdited on: Wed, Feb 2, 2011 at 8:55:51 AMEdited on: Wed, Feb 2, 2011 at 8:56:32 AMEdited on: Wed, Feb 2, 2011 at 8:57:43 AMEdited on: Wed, Feb 2, 2011 at 8:58:19 AM
Edited on: Wed, Feb 2, 2011 at 8:59:45 AM
Wed, Feb 2, 2011 at 8:49:56 AM | Problem with Realist view style graphics
Just because it "looks" correct in 3D doesn't mean it is.  Post a plan cut through the window with an angle dimension from wall to trim ouside the wall.  I bet they are not parallel.
Edited on: Wed, Feb 2, 2011 at 8:50:35 AM
Wed, Feb 2, 2011 at 9:07:31 AM | Problem with Realist view style graphics
vareddirt
Window and all parts are parallel to the wall.  I really think it has something to do with the graphics.  Here are 2 shots of the same windows, one is a camera view, the other is the same camera view, duplicated and rotated a little!  I have a feeling there is no fix for this other than a diff computer.  Anyone else out there seen this???
Wed, Feb 2, 2011 at 9:20:44 AM | Problem with Realist view style graphics
4 Stars: 205 Votes
wierd, this can only be a graphic card issue
Wed, Feb 2, 2011 at 9:26:05 AM | Problem with Realist view style graphics
vareddirt
Typhoon, Yes, that is my conclusion!  Was hoping it would be something easily fixed.
Wed, Feb 2, 2011 at 9:29:48 AM | Problem with Realist view style graphics
4 Stars: 205 Votes
Just in case, do what WW told you in his last post please.
Wed, Feb 2, 2011 at 9:58:26 AM | Problem with Realist view style graphics
vareddirt
It will not do an angular dim when it is parallel, I tried.  I did edit the window family and added 1" to all the trim and now it all looks correct and looks parallel.  Always a work-around! Smile
Realistic Style Help
Mon, Aug 30, 2010 at 8:41:35 AM
graphics problem with revit 2017 (win10)
Thu, Aug 4, 2016 at 3:01:51 AM
Object Style / Visibility Graphics
Thu, Aug 5, 2010 at 3:21:25 AM
Solid filled region not printing with hidden line graphics style
Tue, May 13, 2008 at 12:13:21 PM
Revit graphics, problem with Realistic and Shaded Visual style
Wed, Nov 28, 2012 at 3:56:35 AM
Page generation time: 4.2071
