Forums >> Revit Structure >> Technical Support >> Titleblock Labels
Tue, Feb 1, 2011 at 6:04:45 PM | Titleblock Labels
quentin4d
I created a Title block and under Drawing Title I think I want two separate labels for the two lines of text. I want this because I want to control the line break.
For example, I don't want it to say:
Foundation Plan and Main
Floor Framing Plan
I want it to say :
Foundation Plan and
Main Floor Framing Plan
But there is only one category for Sheet Name. I created "Sheet Name 2" Shared Parameter, but when I insert the title block into project it comes up as Project Information, so I can't change it sheet to sheet.
Tue, Feb 8, 2011 at 8:47:13 AM | Titleblock Labels
emgeeo
3.5 Stars: 7 Votes
You need to add the shared parameter (in Manage->Project Parameters) to the appropriate category:  Sheets.
You'll have to remove the shared parameter you've already imported.
Make sense?
I can walk you through step-for-step if needed.
Wed, Feb 9, 2011 at 10:16:05 AM | Titleblock Labels
quentin4d
that worked. thanks.
Labels don't show in titleblock
Tue, Jan 13, 2009 at 2:34:24 PM
TitleBlock Labels
Wed, Jan 25, 2006 at 8:21:38 AM
Creating custom labels showing area in a titleblock.
Wed, Aug 7, 2013 at 10:40:49 AM
Titleblock Labels (Custom to each sheet) [ 1 2 ]
Mon, Oct 5, 2015 at 2:46:21 PM
21
Titleblock parameters / labels
Tue, Apr 7, 2009 at 12:41:34 PM
Page generation time: 0.7375
