Forums >> Revit Building >> Technical Support >> Slanted column
Sat, Nov 5, 2005 at 6:11:36 AM | Slanted column
puzzle
4 Stars: 10 Votes
I'm sorry if this has already been covered before, but how can you making a column on the angle. If some one does reply, can you keep it basic as I've just started with Revit. Thanks
Macca
Sunshine Coast
QLD Australia
Sat, Nov 5, 2005 at 9:21:00 AM | RE: Slanted column
Rythmick
5 Stars: 2 Votes
Use can use "Create" in Modeling mode to make a "Solid Blend" in the project or if you want to create a column that you can use again and again you will want to make it a family by going to "File" - "New" - "Family" - go to imperial or metric templates - "Columns.rft" and create it as a family, again with the Solid Blend. You can use dimensions as parameters in the family to control base size, top size, slant offset, etc.
Sat, Nov 5, 2005 at 5:57:02 PM | RE: Slanted column
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Here: http://www.revitcity.com/forums.php?action=viewthread&thread_id=592#2062
Sat, Nov 5, 2005 at 9:44:09 PM | RE: Slanted column
puzzle
4 Stars: 10 Votes
thanks for the quick reply. I'll see how I travel. Puzzle
Macca
Sunshine Coast
QLD Australia
Slanted Columns in Revit LT ??
Wed, Mar 13, 2013 at 8:28:19 AM
Mirroring a slanted column
Mon, Mar 10, 2014 at 7:50:04 PM
Can't mirror L Angle slanted column
Mon, Apr 11, 2011 at 9:52:21 AM
Trim on slanted column
Mon, Sep 8, 2008 at 1:20:01 PM
slanted model in place column
Sun, Nov 7, 2010 at 9:01:37 PM
Page generation time: 0.4988
