Forums >> Revit Structure >> Technical Support >> Roof Covered Entry Problem
Mon, Jan 31, 2011 at 11:47:31 AM | Roof Covered Entry Problem
quentin4d
I created this covered entry with the same slope as the main roof, but the valley lines are in the wrong place. How did that happen?
Mon, Jan 31, 2011 at 11:51:01 AM | Roof Covered Entry Problem
You should just make this part of the main roof sketch.  Expeirment with splitting your roof edge line.  In this case, that edge should be split into 4 lines - the outer two have slope assigned.  The split points are at the gutter points and the peak.  Try it....
Mon, Jan 31, 2011 at 11:51:56 AM | Roof Covered Entry Problem
quentin4d
I had to change the Offset from Roof Base. But I had to go the elevation to measure how much to change it. That's annoying. Please tell me there's a better way.
Mon, Jan 31, 2011 at 1:27:34 PM | Roof Covered Entry Problem
4 Stars: 205 Votes
Wierd, I don't have any problem and I didn't split the line..
Mon, Jan 31, 2011 at 1:41:20 PM | Roof Covered Entry Problem
I thought the facia of the entry was aligned with the main roof facia, that is why I suggest to split the line.  If it protrudes, typhoon has the answer.
Mon, Jan 31, 2011 at 1:51:48 PM | Roof Covered Entry Problem
quentin4d
I tried a few different things and it seems that by creating the Roof by Footprint with Pick Walls creates the error. If I use lines and / or offsets, it doesn't have the problem.
Mon, Jan 31, 2011 at 1:58:30 PM | Roof Covered Entry Problem
4 Stars: 205 Votes
That's the problem indeed.
SHEET UNDERLAYING
Fri, Sep 18, 2009 at 2:00:19 PM
new color scheme entry error
Thu, Sep 18, 2014 at 1:42:54 PM
12
roof problems
Thu, Nov 3, 2016 at 6:44:08 PM
How to create a gable roof with sloped eaves
Mon, Feb 29, 2016 at 7:49:27 PM
shed roof with dbl slopes
Wed, Jun 15, 2011 at 8:31:08 AM
Page generation time: 0.5814
