16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> How do you change the cut plane?
3 Posts No Rating |
The things that I would like to show on the Foundation Plan are showing up on the First Floor Framing Plan (ex. footings and piers) and the things I would like to show on the Foundation Plan are cut too deep. (ex. only hatched footings are showing up, no foundation walls) Where can I change the cut depth or the direction of the cut according to the Level?
hi seal76,
mr spot has written many tips on this subject - maybe do a search of threads?
but essentially your issue relates to view properties, then view range. and you change 4 things that control cut plane and view depth. as a beginner, i was told by a more experienced user to think of it the way you create a section or elevation, only horizontally. this helped me understand it a bit more. mr spot also explains in his threads that you can adjust object styles within the view, especially when using structure.
hope that helps
3 Posts No Rating |
Thanks for the reply. I will, indeed, look into that.
Cut Plane display issue |
Tue, Oct 11, 2011 at 12:48:42 PM
Showing High Windows Cut In Plan |
Mon, May 28, 2007 at 3:09:47 PM
Elevation Cut Plane |
Tue, Jul 9, 2013 at 3:46:47 PM
Would like shadows to appear from above cut plane |
Wed, May 2, 2012 at 1:22:44 PM
How to control where the cut plane is for families? |
Sun, Nov 22, 2009 at 10:19:59 AM
