Forums >> Revit Systems >> Technical Support >> Trying to make Title Line Shorter
Fri, Jan 28, 2011 at 11:32:36 AM | Trying to make Title Line Shorter
bxuser
Hello,
I'm trying to make my title line shorter on my sheet, How do I go about doing that?
Thanks
Fri, Jan 28, 2011 at 12:23:50 PM | Trying to make Title Line Shorter
If you are using the Revit stock view title, click on it and a grip will appear at the end of the line for you to adjust it with.
Fri, Jan 28, 2011 at 3:12:00 PM | Trying to make Title Line Shorter
mcantwell
mcantwell Avatar
Click on the view to change the title line length
Click on the view to edit the text
 Having trouble opening a view due to views overlapping - right click on the title and activate view
Sat, Feb 5, 2011 at 12:40:57 PM | Trying to make Title Line Shorter
bxuser
Thanks alot guys........that was it.
Line-length shorter than 1mm impossible?
Thu, Feb 11, 2010 at 9:59:30 AM
Going from "Title w line" to "Plan Title"
Thu, Aug 23, 2007 at 11:53:11 AM
View Title Extension line
Mon, Apr 23, 2007 at 6:38:22 PM
Control Line in View Title Tag
Mon, Jun 11, 2018 at 7:45:48 AM
View Title drawing scale associated to the right and moving with the line
Wed, May 9, 2018 at 5:41:08 PM
Page generation time: 2.1487
