21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> Beam System Rafter Joins
Is there a way to clean up rafter joins from beam systems? If you look at the images attached I am trying to get a clean trim at the rafter intersections. Can anyone help me with this? I feel like I am missing something.
the only way i've gotten this to look right is by creating reference planes on each face of the diagonal member and then individually cutting the joing members using "cut geometry".
Interesting... I will try this. Thank you for the reply!
Sorry as this is not a solution but a question, what tool are you making your rafters with?
I am using the beam system tool for those rafters.
rafter to ridge connectionu |
Wed, Oct 2, 2013 at 4:37:24 PM
Beam Joins and Columns |
Fri, Jul 22, 2011 at 3:06:49 PM
Beam Joins |
Wed, Mar 20, 2013 at 7:32:55 AM
Beam system height VS. Beam height error |
Fri, Jan 22, 2016 at 4:31:20 PM
Detailing a Beam Saddle at Valley Beam |
Wed, Jan 26, 2011 at 12:15:21 PM
