Forums >> Revit Structure >> Technical Support >> linework question
Thu, Jan 27, 2011 at 3:51:48 PM | linework question
davidlowery
OK, so let's say you've performed linework on a bunch of objects and then a week later you want to find out what linestyle you changed the objects to.  How can you tell?
Thu, Jan 27, 2011 at 3:56:22 PM | linework question
No, you can't.  You can always change them back to original using the linework tool then use the linework tool again to change them to a known line.
Thu, Jan 27, 2011 at 5:32:06 PM | linework question
mcantwell
mcantwell Avatar
Start the linework tool
hover over the line
read off the linestyle from the bottom left of the screen
Fri, Jan 28, 2011 at 7:37:00 AM | linework question
You know I had forgotten that.... thanks for that mcantwell.
Fri, Jan 28, 2011 at 12:28:24 PM | linework question
davidlowery
Thanks, that works perfectly.
Can you save linework?
Tue, Aug 12, 2008 at 7:37:07 PM
Linework tool issue
Mon, Sep 26, 2011 at 3:20:44 PM
Improving Linework in Sections & Elevations
Sun, Mar 30, 2008 at 12:30:48 AM
How to delete linework created by underlay
Tue, Jan 31, 2012 at 9:45:57 AM
Linework on column woes
Fri, Apr 29, 2005 at 12:40:35 PM
Page generation time: 0.8111
