Forums >> Revit Building >> Technical Support >> RCP People- gray shade
Thu, Jan 27, 2011 at 2:33:00 PM | RCP People- gray shade
lavendi321
4 Stars: 16 Votes
How can I modify a RCP person (male and female) that comes with Revit, to show gray, and maybe translucent (sort of see thru) rather then the photo realist images that they are?
 is there a way to modify the image, but keep the shape?
Thu, Mar 31, 2011 at 2:49:25 PM | RCP People- gray shade
sypryano
5 Stars: 3 Votes
There is no way to get people, trees, cars, objects to be transparent? Help me, pls
Fri, Apr 1, 2011 at 9:03:57 AM | RCP People- gray shade
gebber
gebber Avatar
5 Stars: 4 Votes
maybe copy the shape in a generic model, aply a semi transparant material?
Fri, Apr 1, 2011 at 11:00:18 AM | RCP People- gray shade
pchan
pchan Avatar
5 Stars: 5 Votes
Under Family catagory and parameter inside family editor, you can change the render appearance source from third party to family geometry, notice that when you do, it will turn of the geometry itself since this is the factory content.
the workaround for this is to create a extrusion like a people cut out shape and apply the material to transluent material, then you should be able to use this family to create the effect.
but of course, if you bring in the image to photoshop, you can do it too
HTH
Gray Dots on My RPC people
Sun, Oct 30, 2005 at 3:26:56 PM
Shade view of toposurface
Fri, May 19, 2006 at 9:35:11 AM
rotating a horizontal sun shade to a vertical sun shade
Fri, May 12, 2006 at 1:14:08 AM
RCP and ArchVision
Thu, Jan 27, 2011 at 2:35:25 PM
shade diagrams
Tue, Apr 21, 2009 at 8:04:33 PM
Page generation time: 0.5036
