20 Users Online (18 Members):
Forums >> Revit Systems >> Technical Support >> Roof curb always vertical?
I'm wondering if anyone has figured out a way to create a roof curb that can be placed on a roof and be always vertical? I'm trying to avoid the slight pitch you'd get when placing RTUs on a flat roof and also be able to specify a minimum height. I've looked here and on the web and can't find a good answer. I've tried roof based; doesn't recognize the roof from the arch linked model. Tried face based; no always vertical function. Tried work plane based; This is the best I've found but still not perfect. It has "always vertical" and can be attached to a face, but the bottom doesn't align to the roof plane and would need to be either extended below the roof or left floating. Does anyone have any other suggestions?
1 Posts No Rating |
I'm looking for the same exact Roof Curb solution. Has anyone had any luck? Advice?
Thanks
RISAKU80,
The solution I ended up using was the one I mentioned above, Workplane based with always vertical. I also extended the curb down a couple inches below the reference level. It's not perfect but it works fairly well.
Equipment Roof Curbs |
Fri, Mar 1, 2024 at 7:13:02 PM
How do I make curb |
Wed, Dec 14, 2011 at 3:57:42 PM
Vertical Fascia on Roof by Extrusion - Is it possible? |
Wed, Dec 4, 2013 at 9:44:49 AM
Possible to change Family category to "Roof" |
Mon, Aug 12, 2013 at 2:32:36 PM
Rendering Images for vertical metal wall panels and standing seam roof? |
Wed, Apr 19, 2006 at 9:13:39 AM
