Forums >> General Discussion >> Revit Project Management >> PDF File Names
Thu, Jan 27, 2011 at 8:59:38 AM | PDF File Names
MetalliCAD
When creating PDF's through Revit, the PDF file name includes the central file name, the users name and then the sheet number and title. Aside from setting the plot option to prompt for the file name, how can set Revit to only produce a PDF with the sheet number and title?
A typical PDF created from Revit is named A-COMP-A11_Username - Sheet - A-001 - Architectural sheet Index.pdf
All I want is A-001 - Architectural shhet Index.pdf
Thu, Jan 27, 2011 at 9:05:47 AM | PDF File Names
That process is dependent on your driver - not Revit settings.  With cute pdf, you have to name each print - no defaults at all.
Thu, Jan 27, 2011 at 12:28:45 PM | PDF File Names
TKennedy
4 Stars: 8 Votes
I have been letting my pdf writer name the files however it wants, then going back with Bulk Rename Utility (free program for Windows) to strip out anything I don't want. It's an extra step, but it seems to be as fast as anything else.
Thu, Jan 27, 2011 at 12:53:03 PM | PDF File Names
MetalliCAD
Ack! It is a hassle to go back and constantly rename PDF's - with or without a utility. I don't believe its a PDF driver issue. It is Revit. It is picking up the central file name and user name from somewhere. Seems like if it can apend that stuff to the file name that there ought to be a way to exclude it.
Wed, Apr 6, 2011 at 8:21:49 PM | PDF File Names
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Have you tried/seen this:
http://www.xrev.com.au/products/Xrev-Transmit
Regards,
Chris.
Thu, Apr 7, 2011 at 8:37:37 AM | PDF File Names
TKennedy
4 Stars: 8 Votes
I've been using the Xrev Transmit trial for the last few days, and I'm really liking it. Now I just have to convince my boss to shell out some cash before my trial runs out.
Can you change a rvt file type to pdf?
Tue, Jun 25, 2013 at 2:30:12 PM
File naming when plotting to PDF
Mon, May 2, 2011 at 11:40:29 AM
Font will not print to pdf file.
Wed, Aug 19, 2020 at 9:16:23 AM
Printing Shadows in .pdf file - Revit 7.0
Wed, Dec 22, 2004 at 9:16:23 AM
Single sheet PDF Naming error
Tue, Nov 23, 2010 at 7:18:24 AM
Page generation time: 1.5673
