23 Users Online (21 Members):
Forums >> Revit Building >> Technical Support >> revit 2010 render
4 Posts No Rating |
when renderig can i directly control the suns ambient light? Also i get some minor spots on the wall. see attached rendering....does anyone know what these spots are
Interior renders are always trial and error. You could change the time of day, and put the sun at horizon or lower, to drop the level of outside light coming in. Or you could change your settings to make it darker while upping the output of your lights to compensate. This may sound confusing, I haven't run any renders in a while, so the terminology is escaping me.
4 Posts No Rating |
yeah i know what ur saying. i want to keep artificial light minimal so the sun can really shine. but yeah i know in max you can handle the "splotchiness" of the light....jw if theres a quick fix in revit. I need stronger ambient light but you cant adjust ambience...only overall intensity ya know
What quality setting are you using? The higher the setting, the lower the splotchiness.
4 Posts No Rating |
not nessecarily, i was on high, printer (10" x 6" at 300 dpi. it doesnt get much better than that with any notiveable differences
That splotchiness is definitely attributed to the ambient light. You may want to try some render searches or ambient light searches to see if someone has had the same issue.
help..can you render a site in Revit Architecture 2010..??? |
Sat, Dec 11, 2010 at 2:21:28 PM
Rendering Families in Revit 2010 |
Mon, Jul 19, 2010 at 5:39:45 AM
RAC 2010 RENDER PROBLEMS |
Mon, Sep 14, 2009 at 4:24:40 PM
Revit 2010 to 3ds Max 2010 Problem |
Thu, Jul 30, 2009 at 9:31:25 AM
Revit 2010 to 3ds Max Design 2010 |
Tue, Aug 11, 2009 at 9:40:37 AM
