Forums >> General Discussion >> Wishlist >> Link Notes
Thu, Jan 27, 2011 at 7:39:02 AM | Link Notes
cboersen
It would be nice to link notes so that if you change one all the other linked notes would all also change.
Thu, Jan 27, 2011 at 7:56:54 AM | Link Notes
Read your help - key notes.
Thu, Jan 27, 2011 at 8:54:57 AM | Link Notes
cboersen
As would be typical of Key Notes they only show the little Key Note tag that refers to a Key Note Legend or Schedule.  If there is a way to actually make the whole note show at each leader rather than just the tag then we would be on to what I am looking for.
Thu, Jan 27, 2011 at 8:59:58 AM | Link Notes
If you read your HELP - Under Placing a Keynote - you will see:
2.  On the Properties palette:
  • In the Type Selector, select a keynote style (Number, Number - Boxed [Large or Small], or Text).
I think the obvious term here is TEXT - right?
Thu, Jan 27, 2011 at 9:15:49 AM | Link Notes
cboersen
Got. it.  Not quite so obvious for a newbe.  I now have a few questions about Key Notes but I will switch to the appropriate forum.
Thanks for the direction.
sharing notes with other projects
Sat, Dec 29, 2007 at 3:25:56 PM
Best Practice for standard notes within drawings
Thu, Dec 10, 2009 at 10:39:36 AM
Specification Sheet (Notes)
Sat, Dec 20, 2008 at 3:27:33 PM
creating General Notes (best practices/ efficient methods) 2017
Fri, Nov 17, 2017 at 4:37:25 PM
Production Text Notes - Global Visibility
Wed, Mar 8, 2017 at 1:43:55 PM
Page generation time: 0.1619
