17 Users Online (15 Members):
Forums >> Revit Building >> Tips & Tricks >> From 24x36 to 30x42 in a flash
We generally do schematic design at 1/8" scale and ConDocs at 1/4" scale so...
We had all sheets setup for 1/8" drawings on 24x36 and had to switch the scale to 1/4" drawings. Naturally the drawings no longer fit on a 24x36 sheet so... rather than setting up all new sheets we just renamed our titleblock family (from 24x36titlblock to 30x42titleblock) and imported the larger format titleblock, overwriting the 24x36 titleblock with a 30x42. You still have to go into every sheet and recenter your elements but it saves time.
Hmm... looks like you can also just load the new titleblock, go into each sheet and swap the titleblocks. Guess it's not as big a timesaver as I thought.
Post edited on 2005-11-04 19:38:10
Setup PDF plotting in Revit |
Fri, Apr 15, 2011 at 10:40:39 AM
Posted Performance of Currently used/tested Revit Systems |
Tue, Jun 30, 2009 at 5:28:46 PM
printing at 90% when i want 100% |
Sat, May 27, 2006 at 3:03:30 PM
Revit plotting problems |
Fri, Aug 12, 2005 at 4:23:36 PM
Revit 7 Teasers |
Tue, Oct 12, 2004 at 9:22:43 AM
