Forums >> Community >> The Studio >> REvit 2011>>FBX>>Max Design 2011 using File link manager
Wed, Jan 26, 2011 at 4:32:53 PM | REvit 2011>>FBX>>Max Design 2011 using File link manager
TYMORO
i cannot get perspective views to link or import into max using the FBX format.  Max reds the file and does nothing, sometimes corrupts the program, not allowing you to create anything new.  is there a file size limitation or should i reinstall or stick to ortho 3d views or ???
ideallly we would like to use the link method.
Thu, Jan 27, 2011 at 9:34:41 AM | REvit 2011>>FBX>>Max Design 2011 using File link manager
TYMORO
The service pack 1 finally corrected this.  I had to go directly to autodesk though to get it because the subscrition and communication center was also corrupt.  Things are working much better now importing and linking fbx.
Revit FBX to 3D Max 2011 causes black or unresponsive viewports
Fri, Jan 13, 2012 at 11:29:51 AM
Transfer materials to max with FBX, material names problem
Mon, Nov 22, 2010 at 5:06:38 PM
Exporting FBX file from Revit to 3Ds Max
Wed, Sep 30, 2020 at 1:36:49 PM
Revit FBX causes 3DS Max to crash
Wed, Aug 10, 2016 at 6:02:27 PM
Revit 10 Model to FBX to 3Ds Studio Max Design lighting problem
Sat, May 1, 2010 at 12:55:25 PM
Page generation time: 2.9722
