Forums >> Revit Structure >> Technical Support >> Section Cut Quandry
Wed, Jan 26, 2011 at 12:06:16 PM | Section Cut Quandry
AllanLong
AllanLong Avatar
Section cuts on a second floor framing plan produce an error message reading "none of the created elements are visible in Structural Plan: Level 2 view.  You may want to check the active view, its parameters, and visibility settings, as well as any plan regions and their settings."
The section IS created on the level above and below - but not the middle level.  And when viewing the section, I see the Level 2 framing.  It just won't place a section mark on that Level 2.  I assume I have some setting wrong, but don't know where to start.
Thanks much!
Wed, Jan 26, 2011 at 12:14:53 PM | Section Cut Quandry
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
check scale of plan view and check to see if the section marks have been turned off in that particular plan view. Section marks can be set not to show up in smaller scales. Section markes can be turned off, and on in VG.
Wed, Jan 26, 2011 at 12:22:09 PM | Section Cut Quandry
AllanLong
AllanLong Avatar
Scale is set as on the other levels (1/8"Winking - and we tried changing the scale for that level to 1/4" to no avail.  And I confirmed that the sections are turned 'on' within VG - annotations tab.
Wed, Jan 26, 2011 at 12:51:45 PM | Section Cut Quandry
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
did you accidentally hide them check for hidden objects witht the " reveal hidden objects light bulb at the bottom of the screen."
Wed, Jan 26, 2011 at 12:55:16 PM | Section Cut Quandry
AllanLong
AllanLong Avatar
good thought - but that doesn't appear to be the case. I tend to think i have some setting wrong.
Thu, Jan 27, 2011 at 6:49:26 AM | Section Cut Quandry
AllanLong
AllanLong Avatar
I was able to resolve this particular issue by applying the View Template from the level below to the problem level.  Presto!  it's fixed.  Still unsure on why the problem existed in the first place, but this is a swell work-around.
Cut Pattern in Plan vs Section
Tue, Aug 25, 2009 at 8:47:59 AM
Sections cut on mulitple sheets
Fri, Jun 27, 2008 at 12:33:38 PM
Is it possible to not have the bold section cut lines
Thu, Apr 3, 2008 at 12:58:16 PM
Segmented section cut
Wed, Oct 10, 2007 at 1:19:40 PM
Animate section cut?
Sat, May 29, 2010 at 5:15:48 AM
Page generation time: 0.3591
