Forums >> Revit Building >> Technical Support >> How to select void extrusion
Wed, Jan 26, 2011 at 11:24:33 AM | How to select void extrusion
jbhearn
Can anyone tell me how to select a void extrusion for edititng after it is created and finished? It cuts out the wall as expected but I need to change its size and can no longer find it!
Thanks in advance for any help,
JB
Wed, Jan 26, 2011 at 12:12:04 PM | How to select void extrusion
Thread Post Kudo! #2
This is an in-place element .... and I am sure you named it and placed it in a category - so look for it in your browser - click on it and choose edit.
Tue, Apr 26, 2011 at 7:50:44 PM | How to select void extrusion
momarch
Just joined this site and happened to see your post.  The easiest way is to hover the cursor over the wall where the edge of the void is and if you can't click on the void edge immediately (not the void, itself), hover over the edge and tap the tab key until you cycle through all the edges and the void edge shows up. Then you can click on it and then click "edit in place" in the ribbon and then hover the cursor again over the void edge and the whole void will show up.  You can then click on it and edit it.
Void Extrusion in window family problem
Mon, May 18, 2015 at 3:55:23 PM
void extrusion not cutting solid extrusion
Fri, Oct 10, 2008 at 3:47:43 PM
Make void extrusion permanent
Wed, Feb 9, 2022 at 6:46:57 PM
Void Extrusion
Tue, May 28, 2013 at 8:15:38 PM
Cut a void from an extrusion
Thu, Feb 19, 2015 at 1:08:44 AM
Page generation time: 0.4100
