Forums >> Revit Building >> Technical Support >> IS IT POSSIBLE TO SPOT ELEVATIONS OF A WALL IN A FLOOR PLAN?
Tue, Jan 25, 2011 at 1:21:33 PM | IS IT POSSIBLE TO SPOT ELEVATIONS OF A WALL IN A FLOOR PLAN?
hgrimberg
Is it possible to place the elevations like the T.O.W. and B.O.W. (top of wall...) on a floor plan like the foundation plan? I can only do it for floors, but not for walls. Maybe Autodesk should know that architects do this...
Tue, Jan 25, 2011 at 1:25:12 PM | IS IT POSSIBLE TO SPOT ELEVATIONS OF A WALL IN A FLOOR PLAN?
If you are really above the top of the wall, you can use a spot elevation tag.... but you are not - correct?  We use wall tags that have an extender for top of wall conditions.  You could create an annotation that is not automatic.
rotating spot elevations on plan
Fri, Mar 6, 2015 at 12:14:14 PM
Setting a manual height for Spot Elevations in plan
Wed, May 27, 2015 at 8:03:11 AM
Revit refusing to use Spot Elevations
Mon, Oct 14, 2013 at 3:47:54 PM
13
Spot Elevations on curved walls with varying height
Tue, May 3, 2011 at 5:26:46 AM
Spot Elevations In Plan
Mon, Aug 7, 2006 at 5:14:23 PM
Page generation time: 3.4215
