9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> Raster Image display
28 Posts No Rating |
I am trying to use a raster image as an underlay to draw a floor plan but when you put any walls or floors in it completely covers up the image. Is there a way to edit the image to be an underlay or possibly screen the image in Revit? Need to get plan out for client today. Thank for you help
John Fleming.
Have you tried setting your view to Wireframe? (WF is the shortcut). It may let you see through then to the image.
Tom
Yep, that works, thanks. Now if I could change the visablity of it. A way to make it more transparent, other than editing it in photoshop or the like.
John
Post edited on 2005-11-04 15:37:08
Revits image tools are very limited.
Basically in revit all you do is rotate the image in 90 degree increments and change its size...
hi I must be doing something stupid but how do you see raster images. what i did was go to a plan view file-import-images then i loaded both tiff and jpeg but all i get is the frame. am i missing something obvious? cheers. usuing revit 2009
ok i remembered that i did this a while ago so found the ols file and tried to attach in my image and it didn't work. anyway i figured that it may be to be with the size of the image so i resized it. now it works. so question now is what is the max size an image can be to import. thanks.
Raster Image |
Fri, Jul 31, 2009 at 8:24:24 AM
Raster Image Draw Order |
Wed, Feb 18, 2009 at 1:16:00 PM
PDF Raster image as a super imposed backgroud |
Sun, Nov 7, 2010 at 8:46:58 PM
Raster Image Content Blank-2010 |
Fri, Aug 28, 2009 at 12:39:02 PM
Help!!! Trouble with printing any raster image (revit 2010) |
Tue, Aug 18, 2009 at 7:48:50 AM
