Forums >> Revit Building >> Technical Support >> Print to PDF with transparent background!
Tue, Jan 25, 2011 at 1:00:49 AM | Print to PDF with transparent background!
craighowie
Hi there.
Is there a way in Revit to print a PDF with a transparent background? Like one would do in AutoCad?
I am wanting to take simple line drawing from revit into photoshop to do some colours and this process would be made so much easier if the background of the image was already transparent.
Thanks,
Craig
Tue, Jan 25, 2011 at 7:08:43 AM | Print to PDF with transparent background!
No , you can not do this from Revit.
Tue, Jan 25, 2011 at 7:23:51 AM | Print to PDF with transparent background!
craighowie
Thanks for the response! Is there any special techniques that I should know about? Revit can't export an eps file at all can it?
 Any idea why the transparency happens by default when printing to pdf in autocad, yet revit can't?
Tue, Jan 25, 2011 at 8:12:03 AM | Print to PDF with transparent background!
craighowie
Oh I believe that archicad does it just fine! Surely revit can aswell...
Transparent pdf
Wed, Feb 21, 2018 at 5:27:47 PM
Text Background Mask Disappearing in PDF's (Revit Architecture 2009)
Thu, Feb 12, 2009 at 1:29:29 PM
Transparent Floor Plan when printing to PDF?
Fri, Apr 17, 2009 at 1:06:25 AM
Help: Print transparent objects from floor plan view to pdf in revit 2013
Tue, May 8, 2012 at 2:49:41 PM
Background image plots in the foreground
Fri, Feb 29, 2008 at 5:24:47 PM
Page generation time: 0.1996
