Forums >> Revit Building >> Technical Support >> Rotating Viewports without rotating title
Fri, Nov 4, 2005 at 11:57:16 AM | Rotating Viewports without rotating title
tmcentire
Is there a way to rotate a viewport on a sheet without also rotating the title mark of the viewport? Or at least is there a way to rotate the title mark back into postion after the viewport rotate?
Fri, Nov 4, 2005 at 12:18:14 PM | RE: Rotating Viewports without rotating title
arccodex1
3 Stars: 1 Votes
I go to Tools... Project Position/Orientation and Rotate True North. Then if you go to View Properties you can orient a project by Project North or True North. Post edited on 2005-11-04 12:21:56
Fri, Nov 4, 2005 at 2:48:53 PM | RE: Rotating Viewports without rotating title
Rythmick
5 Stars: 2 Votes
Rotate the title; Open the View Title family and rotate it in the family - rename (Save As) and then load into your project. Select the view title - go to properties - Edit / New - Duplicate and assign the "Title" parameter to your new family. Post edited on 2005-11-04 15:19:29
Fri, Nov 4, 2005 at 4:11:20 PM | RE: Rotating Viewports without rotating title
arccodex1
3 Stars: 1 Votes
Rythmick How do you get the viewport itself to rotate? Does the extension line rotate as well? It looks like you can also rotate views if you establish a crop region for the view. Post edited on 2005-11-04 17:27:24
Fri, Nov 4, 2005 at 5:04:05 PM | RE:
Rythmick
5 Stars: 2 Votes
Quoting arccodex1 - 2005-11-04 16:11:20
"Does the extension line rotate as well?"
It doesn't appear to, but you can toggle it off in the type parameters and draw one in.
Post edited on 2005-11-05 00:34:29
Fri, Nov 4, 2005 at 5:07:05 PM | RE: Rotating Viewports without rotating title
Thread Post Kudo! #6
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
EASIEST WAY: PLACE VIEW ON SHEET. ACTIVATE THE VIEW. SELECT THE CROP REGION. ROTATE THE DESIRED AMOUNT. NOTE THE VIEW ROTATES AND THE CROP REGION REMAINS THE SAME. THIS ALLOWS YOUR VIEW TITLE TO REMAIN HORIZONTAL.
Fri, Nov 4, 2005 at 5:38:18 PM | RE: Rotating Viewports without rotating title
arccodex1
3 Stars: 1 Votes
That's for plans... if for some reason you wanted to rotate sections or elevations you'ld have to use Rythmick's solution (view rotation on sheet.. 90 clockwise - haven't figured out counterclockwise yet because the view title text isn't cooperating). Legends are easy enough to rotate, haven't figured out if you can rotate schedules. One would probably only need to rotate plans anyway. Post edited on 2005-11-04 17:47:05
Sat, Nov 5, 2005 at 12:26:32 AM | RE:
Rythmick
5 Stars: 2 Votes
Quoting arccodex1 - 2005-11-04 17:38:18
"haven't figured out counterclockwise yet because the view title text isn't cooperating."
You need to create a third View Title family, rotate the original clockwise 90 deg and in each one of the label properties toggle off the "Keep Readable" box.
Sat, Nov 5, 2005 at 12:46:38 AM | RE: Rotating Viewports without rotating title
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I guess maybe for presentation drawings you may need to rotate elevations. But in construction documentation i don't see a need... Couldn't you just rotate the titleblock?
Wed, Apr 22, 2009 at 10:52:58 PM | Rotating Viewports without rotating title
romayama
Mr.Spot, that's freaking AWESOME! Thanks!!!
Rotating Views On a Sheet [ 1 2 ]
Tue, Jun 17, 2008 at 12:49:46 AM
18
Rotating Views on Sheet
Tue, Jan 19, 2010 at 12:30:55 PM
Rotating mullions
Thu, Jul 24, 2008 at 4:27:53 PM
Rotating Symbol geometry without rotating leabel
Wed, May 6, 2009 at 8:33:58 AM
Rotating View Titles
Sun, Feb 8, 2015 at 2:10:09 PM
Page generation time: 0.2311
