Forums >> Revit Systems >> Technical Support >> Default Elevations of Families
Mon, Jan 24, 2011 at 11:32:09 AM | Default Elevations of Families
pmobleyjr
3 Stars: 1 Votes
I am working in Revit MEP 2011. I am having problems with the default elevations of the families. I am not sure what is going on but when I bring in an object like the Electrical outlets one time it places them at the default elevation of 1'6" the next time I place one it comes in at 0'0". I have even purged them reloaded them and they continue to do this. I have checked and double checked what my defaults are and all seems to be fine. It is only this Family type and the Communcations families that do this data and all other work great. I have even tried to take one of those and change the family type to eletrical and it still does the same thing. I am at my wits end. Anyone have any suggestions.
Edited on: Mon, Jan 24, 2011 at 11:34:52 AM
Tue, Jan 25, 2011 at 12:01:55 PM | Default Elevations of Families
Eddieboarder91
Eddieboarder91 Avatar
4 Stars: 8 Votes
you should be able to change the elevation as you are placing them in the properties palette. You dont need to worry too much about the default elevation. Unless of course you are placing 1 at a time and then escaping and going back into the command.
www.allbimallthetime.blogspot.com
http://familyjewels.typepad.com/
Tue, Jan 25, 2011 at 2:54:02 PM | Default Elevations of Families
pmobleyjr
3 Stars: 1 Votes
OK I am seeing that I am going to have to live with it that way. Now it brings me to the question of is there any way to link that elevation from the properties box there to a tag to label the mounting height for the family chosen?
Thu, Feb 10, 2011 at 2:43:28 PM | Default Elevations of Families
Eddieboarder91
4 Stars: 8 Votes
You should be able too. Use the electrical equipment tag then edit it and you should be able to add either elevation or offset to the label in the family editor. Then you should just need to load it back into the project and it will update auto.
Default Elevations missing in project
Fri, Apr 5, 2013 at 7:21:37 AM
Edit Default Families
Sun, Jan 24, 2010 at 8:23:42 AM
Default templates and families missing from Revit 2016
Sat, Jul 15, 2017 at 10:14:48 AM
Families that are "behind" cut showing up in interior elevations.
Wed, Jan 23, 2008 at 10:50:16 AM
Tagging Default Elevation Parameter for Face-Based Families
Wed, Aug 13, 2014 at 8:57:26 AM
Page generation time: 1.4433
