33 Users Online (31 Members):
Forums >> Revit Building >> Technical Support >> Move room area to other level
9 Posts No Rating |
Hi I'm sketching on a project that have several levels with different kinds of functions described by room areas / tags and grouped by departments. I have setup all departments in schedules and given them numbers. Now, as it often happens in this sketching phase, functions has to move to other locations, on other levels. This is where I get some troubbles. How can I move a 'room area' to a other level without having to rewrite the room numbers ? If I just cut and paste the area it gets a new number :-/ I hope some have had this issue and found a solution :-) Thanks
Revit will always assign a new room number - but no problem, just change it.
9 Posts No Rating |
Hi wwhub Not the answer I hoped for :-/ The problem is, that departments consists of lot of rooms, more than 20, and it's a lot of renumbering :-( But thanks, I now know that there is no other way Thanks
if you have alot to change, i have found it is quicker to change them from a room schedule rather than from the plan view.
----------------------------------- PWD |
move Room Tag to different level |
Thu, Sep 18, 2014 at 11:21:09 PM
Room schedule - area |
Tue, Nov 9, 2010 at 1:07:43 PM
room area calculation |
Thu, Jan 15, 2009 at 5:51:20 AM
Room tags with area - area not showing up! |
Thu, Aug 16, 2007 at 6:54:26 PM
Level parameter problem in tags |
Sat, Jul 21, 2018 at 6:13:21 AM
