Forums >> Revit Building >> Technical Support >> How to tag a structural beam system?
Sat, Jan 22, 2011 at 2:15:54 AM | How to tag a structural beam system?
hgrimberg
I am trying to tag a structural beam system composed by many joists and it seems impossible even though I loaded the Structural beam system tag. I can't select the structural beam system, it just selects the individual joists and tags them but not the whole system. Somebody has been through this and know how to do it?
Thank you.
Mon, Jan 24, 2011 at 1:58:22 PM | How to tag a structural beam system?
kbeegles
Under annotations there is a button for beam system tag, separate from the standard tag tool.  Use this and click on the beam system and you should be good to go.
The Leffler Group
Tue, Jan 25, 2011 at 11:11:02 AM | How to tag a structural beam system?
hgrimberg
I didn't find any special button for structural beam systems under Annotations. Maybe there is one on Revit 2011. I am still using 2010 and maybe this was a bug that Autodesk realized about this mistake and fixed it on 2011. Thank you for your help anyway.
Tue, Jan 25, 2011 at 11:15:59 AM | How to tag a structural beam system?
kbeegles
Under Annotate, in the "Symbols" area there is a button that says 'Beam' next to it and has a little span direction graphic.  This is available in both 2010 and 2011, so you should be able to find it in either version.
The Leffler Group
Tue, Jan 25, 2011 at 1:52:00 PM | How to tag a structural beam system?
hgrimberg
Humm, I dont find this button that says beam that you are talking about. Maybe it comes with service pack 1 which I didn't download yet. Thank you for your help!
Thu, Jan 27, 2011 at 7:08:31 AM | How to tag a structural beam system?
Blazarch
Beam system symbol is available in RST2010. Click Annotate tab>Symbol panel>Beam.
Maybe there's something wrong with your REVIT program. See attached family, try to load it into your project. Hope it could work.
Blazarch is a leading CAD drafting & BIM services provider in Shanghai, China. Blazarch assists global design professionals in design and drafting of architectural, structural, HVAC, electrical, plumbing and building information modeling. Visit http://blazarch.com/ for details.
Thu, Jan 27, 2011 at 9:18:33 AM | How to tag a structural beam system?
hgrimberg
Hi,
tHERE IS NO sYMBOL TAB UNDER aNNOTATIONS,  All I have is Dimension, Detail, Text and Tag. If I try to add it your annotation as a symbol and I upload it, then it doesnt show up under symbols nor as a detail component...
It seems this is a bug on Revit...
Mon, Feb 11, 2013 at 4:04:43 PM | How to tag a structural beam system?
sangre
I know that this is an old post but I want to help those that land on the page looking for answers. I have been searching for two days to make a structural beam system tag. I know that it is possible in 2010 but i couldn't find the button. I believe that those that state that the don't have a beam button under the symbols section of the annotation tab it may be because of it being the 64bit version. I have looked at a 32 bit system and I can find it in there. So if you hit the forum looking for a way to get the structural beam system tag, the replies that insist that you should have it in the annotation tab will be from people with the 32 bit version.
Beam System Tag
Fri, Aug 14, 2009 at 3:09:33 AM
structural beam system visibility
Fri, Jun 27, 2008 at 12:24:51 PM
Automatic Beam System and Tag On Options
Wed, Nov 26, 2014 at 7:29:00 PM
Adding a beam system issue
Sun, Jun 15, 2014 at 2:58:10 PM
structural beam system irregularity
Fri, Dec 19, 2008 at 3:03:10 PM
Page generation time: 3.4478
