Forums >> Revit Building >> Technical Support >> How to fill area with symbols/blocks?
Fri, Nov 4, 2005 at 11:48:25 AM | How to fill area with symbols/blocks?
porcarius
Is there any possibility how to fill areas in AutoCAD with symbol pattern (see the sample)? I would like to create pattern of trees which will be repeatedly distributed within the area. I tried to do it with HATCH entity, but it seems that it can be created just using lines. I could imagine that there could be possibility to define symbol as BLOCK (containing single tree symbol) and this symbol could be used to create pattern. I expect that symbols of pattern will contain arcs. Any ideas ? porcarius
Fri, Nov 4, 2005 at 3:13:20 PM | RE: How to fill area with symbols/blocks?
Rythmick
5 Stars: 2 Votes
Did you try to import the pattern into your site view? Once imported you can group if necessary and copy to other locations.
Fri, Nov 4, 2005 at 5:16:08 PM | RE: How to fill area with symbols/blocks?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You can use a program called hatchkit to create custom patterns that can be used as fill patterns. Note that surface patterns will not display on a topography.
Mon, Nov 7, 2005 at 9:32:43 AM | RE: How to fill area with symbols/blocks?
porcarius
Thanks for comments - I have posted this query also on Autodesk forum and got promising response from creators of HatchKit (it is possible to create quite complex hatch patterns using this tool). Regards, Petr.
Area Plans with Color Fill Through Walls
Thu, Oct 8, 2015 at 6:50:30 AM
Revit Detail Level fill pattern, Texts in Elevation and Section's Symbols
Mon, Jul 30, 2012 at 7:12:54 AM
Exporting symbols as blocks in Autocad
Thu, Aug 1, 2013 at 10:10:00 AM
Area Legend not showing
Fri, Mar 14, 2014 at 1:00:17 PM
Revit Arch. 2009 - Floor Plan Solid Fill blocks out walls
Mon, Mar 30, 2009 at 2:22:09 PM
Page generation time: 0.9802
